OFFROADSUBARUS.com
Go Back   OFFROADSUBARUS.com > General Forums > Members Journals
  #51
Old 23rd October 2017, 11:20 PM
andymccauley andymccauley is offline
Member
Year: 81
Model: DL
Transmission: Manual 4spd
andymccauley is on a distinguished road
The spacer I made out of 1/2" pipe and some longer m6x1.0 bolts, cut 2 peices of pipe to 5/8" roughly and had to back the cable adjuster out as far as physically possibly.
  #52
Old 24th October 2017, 12:30 AM
Kevin Kevin is online now
Bit by bit it's coming together!
  #53
Old 24th October 2017, 10:07 AM
Member
Year: 81
Model: DL
Thanks Kevin, it's pretty much gunna be a waiting game now for parts and money for odds and ends.
Still need to order a fuel pump, radiator fan, get stuff for wire splicing. Figure out which radiator I'm going to use. Might need a little more 5/16 EFI hose. Alot of zip ties for hanging the wiring harness.
  #54
Old 24th October 2017, 04:39 PM
And winter is coming, how will that affect your efforts?
  #55
Old 25th October 2017, 01:48 AM
Member
Year: 81
Model: DL
I have a garage, and I'm not afraid to work in the cold. I gotta change the clutch in the rabbit, after that I'll probably get it in the garage for a few things.
  #56
Old 25th October 2017, 03:48 AM
^ cool (pun intended!) ;-)
  #57
Old 17th November 2017, 05:36 PM
El_Freddo's Avatar
Senior Member
Year: 1988
Model: EJ22'd L series
Transmission: Locking Centre Diff 5spd Manual 4.111:1 diff ratio with 1.59:1 low range and a front OBX LSD ;)
Has this work slowed down?
I'm hoping not - keep it going, chip away at it and you'll have it sorted in no time, even though it feels like it'll take you ages!
  #58
Old 19th January 2018, 02:51 AM
Member
Year: 81
Model: DL
Haven't had anything to update for awhile had to put a new clutch in the daily VW Rabbit. Had a tranny seal blow out and coat everything in gear oil, causing it to slip.
I'll get back to it soon.
  #59
Old 18th March 2018, 01:38 PM
Member
Year: 81
Model: DL
Been awhile since I've even touched this thing. But made some progress yesterday. Got spark n fuel, not sure if the injectors are firing or not, might be missing a ground somewhere in the harness.
So I changed all the fuel lines underneath and figured out where I want to mount the fuel pump. Gunna run wires to it from where the plug was on the EJ harness.
  #60
Old 18th March 2018, 07:15 PM
Member
Year: 81
Model: DL
Hooked up the noid light and got injector pulse, won't fire though. got fuel, spark, injector pulse, I don't have an O2 sensor yet though.
