OFFROADSUBARUS.com
Go Back   OFFROADSUBARUS.com > General Forums > Members Journals
User Tag List
  #141
Old 16th August 2017, 02:18 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Senior Member
Originally Posted by Escher View Post
Axles from the SVX in a Forester? That would be epic!
Yes, swap is done and it works great
Quaife f/r, HotBits, DCCD, 1,59:1, EJ22
  #142
Old 17th August 2017, 02:10 AM
Rally's Avatar
Rally Rally is offline
Senior Member
Year: 2004
Transmission: Custom hybrid D/R 1.446, Twin Lockers, R180, Front LSD, 4.44, 0.738 5th Gear
I'm running STI rear axles in my Forester- they fit straight in. (assuming you have matching diff and hubs). They are noticeably thicker than the normal Subaru axles. How thick are the SVX ones?
E-locker and DCCD.
  #143
Old 17th August 2017, 07:55 AM
jf1sf5's Avatar
Senior Member
SVX axles are about the same thickness as 4EAT '96 Legacy axles, will measure accurately later. But the CV joints are 6mm OD larger.
  #144
Old 6th December 2017, 06:28 AM
scalman scalman is offline
Senior Member
Year: 2001
Transmission: 4eat
Sorry wrong post
  #145
Old 7th December 2017, 06:05 PM
jf1sf5's Avatar
Senior Member
Originally Posted by scalman View Post
Sorry wrong post
  #146
Old 8th December 2017, 01:04 PM
Senior Member
Year: 2001
Transmission: 4eat
but your car as many other australian builds here are amazing. so many stuff in them that we in europe side couldn't get .
  #147
Old 8th December 2017, 01:34 PM
jf1sf5's Avatar
Senior Member
Hmmm...Switzerland is geografically in Europe...but not politically because we are a democracy !
You should be able to find any bits and pieces for your Outback in Europe or import them from anywhere else like I did for the suspension, the previous front CV axles and the DCCD controller only.
  #148
Old 8th December 2017, 01:40 PM
Senior Member
Year: 2001
Transmission: 4eat
thanks. do you have like list of your cars mods like in one place ? or i need read all and search for it. and i suppose outback need different parts then any forester ?
Last edited by Kevin; 8th December 2017 at 05:45 PM. Reason: Unnecessary use of Quote
  #149
Old 8th December 2017, 01:57 PM
jf1sf5's Avatar
Senior Member
Yes, your Outback BH has a different chassis than the '97-'08 Foresters, at least the rear multi-link suspension. The other parts like the engine/gearbox can usually be swapped with little modifications.
Most of the mods I did can be found here in my journal.
