  #131
Unread 14th November 2014, 05:56 PM
Forester Forester is offline
Year: 1999
Transmission: Auto
Forester is on a distinguished road
Nacha, you have modified you're trailing arms, is there a how-to? Any thoughts about it?
Or better do I use spacers for a max 2" lift?
'99 Forester s-Turbo
www.subaruclub.nl
  #132
Unread 14th November 2014, 10:53 PM
NachaLuva's Avatar
NachaLuva NachaLuva is online now
Trailing Arm Spacers are a much better way of doing it. I'm going to remove my longer TAs as they push the wheel too far back under full compression. TA spacers are much better at keeping the correct angles as the wheel swings through it arc as it compresses.
Have a look at Trailing Arm Blocks
  #133
Unread 20th November 2014, 11:19 PM
NachaLuva's Avatar
Started going through the GoPro vids from Echo Camp Backtrack, Arkaroola. Found a good example of the Subaru AWD system with rear plated LSD at work:
  #134
Unread 21st November 2014, 01:46 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Nice, your plated LSD seems to work well.
And the location of the GoPro is perfect to see it work !
Subversive...
  #135
Unread 27th January 2015, 04:07 AM
NachaLuva's Avatar
Suffered a little damage (bent strut) doing a black diamond run & a double black diamond:
So...time for some SG rear struts for better tyre clearance plus upgrade the strut tops for more caster?camber.
Front:
Rear:
I also put in a new rear wheel bearing in a new (old) hub. I also found the axle outer cup was worn so chased down a new axle.
Then I finally fitted my HID driving lights. The wiring & relay had been done ages ago when I upgraded my headlights, so it was just a matter of making a mount for it & adding the wiring from the lights to the relay
  #136
Unread 27th January 2015, 04:12 AM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
All looks terrific, NL .
Bugger about the busted strut and wheel bearing/axle.
  #137
Unread 29th January 2015, 06:21 AM
zippo zippo is offline
Guest
Year: 2007
Model: Forester X
Transmission: 5MT
zippo is on a distinguished road
Couldn't help notice your choice of refrigerant for the A/C system ....
  #138
Unread 30th January 2015, 07:09 AM
NachaLuva's Avatar
Hadn't noticed lol, was there when I bought it
  #139
Unread 10th January 2018, 06:19 PM
1WD Foz 1WD Foz is offline
Year: 98
Transmission: Manual 5 speed
hey mate would love to see how your rides going now
update bump ??
  #140
Unread 26th January 2018, 07:16 PM
NachaLuva's Avatar
update bump ??
Been so much done to Marvin since the last post, will have to spend some time posting photos
