  #451
Unread 2nd January 2018, 05:40 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Model: SG Forester X MY05 | SVX
Transmission: 5MT D/R | 4EAT
Much of a noise when it locks?
SLO White Foz, Quicksilver Tri-Colour SVX!
  #452
Unread 2nd January 2018, 05:55 AM
Rally's Avatar
Rally Rally is offline
Younger than Kevin
Year: 2004
Can't hear it at all
  #453
Unread 2nd January 2018, 06:34 AM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
How did you test it, straight ? Maybe does it activate better when both wheels don't rev at the same speed, like when turning ?
Subversive...
  #454
Unread 2nd January 2018, 06:57 AM
Rally's Avatar
Younger than Kevin
Year: 2004
I turned on while stationary, as per instructions. I then took off and drove a few metres and performed a U-turn, with no binding. I then drove maybe 50 metres and performed a u turn, with notable binding. So it's less than 50 metres, but how much less I don't know yet.
  #455
Unread 10th January 2018, 11:29 PM
Rally's Avatar
Younger than Kevin
Year: 2004
Too many instruments, not enough room. Solution- one instrument that does the lot. Volts, boost, water temp, oil temp, oil pressure, speed, RPM, EGT, AFR. It even has shift lights.
  #456
Unread 10th January 2018, 11:58 PM
Nice
  #457
Unread 11th January 2018, 12:17 AM
NachaLuva's Avatar
NachaLuva NachaLuva is online now
That's awesome!!
  #458
Unread 11th January 2018, 01:57 AM
Rally's Avatar
Younger than Kevin
Year: 2004
Tacho and speedo connected. Now for the more difficult part. Getting the huge mass of wires through the firewall and installing the egt and oil temp sender units
  #459
Unread 11th January 2018, 07:46 PM
NachaLuva's Avatar
How are you connecting these, do you piggy back off the factory sensors? So the ECU & dash still gets the factory output & this race dash gets inputs too. But wouldn't that halve the voltage?
  #460
Unread 11th January 2018, 11:09 PM
Rally's Avatar
Younger than Kevin
Year: 2004
When I did the engine conversion, I ended up doing a pin out list of every wire going to the cluster so I knew what was what in order to get the speedo, fuel and temp gauge working. So looking at that, I spliced into the signal wire going to the speedo and tacho. They are the only factory sensors I will be using, except maybe for the AFR's. However, when I calibrate the speedo, I will be using the GPS to give me the speed reading baseline. Unfortunately, you have to calibrate it at 40kmh, so we'll see how it maintains it's accuracy at higher speeds.
With regards the AFR's I can't use the O2 sensor in the car as it is a wide band sensor, and the dash will only work of a narrow band. I think I threw my old narrow band one away so I'll have to find another.
It is better to have independent inputs so the lack of ODB never concerned me.
