  #1
Unread 22nd January 2018, 05:03 PM
GreenSuby GreenSuby is offline
Year: 2004
Transmission: Manual
GreenSuby is on a distinguished road
Default 2010 outback obd
Gday all
There's a bloke at work that has been having trouble with his 2010 outback diesel. I offered him my obd bluetooth reader to find the codes, etc but he can't find the obd port. Nothing is mentioned in the manual.
Does anyone know where it's located?
Thanks
Greensuby
  #2
Unread 22nd January 2018, 08:09 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
Should be on the bottom of the steering column, near where the lower lip of the dash panel is.
  #3
Unread 22nd January 2018, 10:39 PM
From here: https://itstillruns.com/do-connect-o...k-7225033.html
This:
Remove the lower dashboard panel on the driver side of your Subaru Outback. It is the panel located in the space between the bottom of your steering wheel and your gas and brake pedals. The panel should simply pull off.
Look for the OBD-II data link connector (DLC). The connector will have 16 pins arranged in two rows of 8. It will be unplugged and should resemble the connection on your OBD-II scanner.
  #4
Unread 22nd January 2018, 11:21 PM
Year: 2004
Thanks guys.
I told him that was the general area. Just it wasn't in the open like most & theres nothing in the owners manual.
Greensuby
