  #1
Unread 28th April 2017, 11:31 PM
raynman1989 raynman1989 is offline
Year: 1991
Model: L series
Transmission: Auto
raynman1989 is on a distinguished road
Default L series vs 2000+ outback
Just wondering what people think is better for light to medium off roaring usually on sand.
I've currently got a 5spd l series with an ej22 which will soon have a 2" lift kit and 26" M/Ts but i was thinking of selling it and buying a newer outback. Obviously the outback would be a much nicer car in general but how would it compare off road and on road with a 2"lift and bigger tires like my l series?
There's 2 main reasons I want to sell the l
1, rust. It's got a bit and it'll only get worse
2, not engineered for the ej22
What are people's thoughts?
Cheers.
  #2
Unread 29th April 2017, 12:34 AM
El_Freddo's Avatar
Year: 1988
Model: EJ22'd L series
Transmission: Locking Centre Diff 5spd Manual 4.111:1 diff ratio with 1.59:1 low range and a front OBX LSD ;)
Sounds like you've already answered your own question...
Both would be as good as each other on sand. But remember the outback won't have the good low range in it.
Rust can be sorted if you're dedicated/keep on top of it.
2 inch lift and some larger tyre on the outback would probably net you a nicer ride with just as much capability as the L on sand.
  #3
Unread 30th April 2017, 11:05 PM
Year: 1991
Model: L series
Transmission: Auto
I've heard the 4wd in the l series is better and that it's difficult to lift the rear end of outbacks?
  #4
Unread 1st May 2017, 01:22 AM
NACHALUVA is very good a lifting rear ends
  #5
Unread 2nd May 2017, 10:05 AM
El_Freddo's Avatar
Year: 1988
The multi link rear end is "tricker" but really is no different to lifting an L series - lift blocks between body and subframes. This only applies to Gen3 onwards.
Define better in your sentence about the 4wd! They have the good low range and engaged centre for a locked front to rear coupling. What they also come with is small tyres and small brakes with an underpowered engine. These can be modified or purchased already done in the outback. Then trick out minor things. Big one could be a custom box if you really wanted to get the best out of your subi. This area is always overlooked IMO.
