  #11
Unread 18th February 2016, 07:04 PM
Ratbag's Avatar
Ratbag Ratbag is offline
Year: MY06, MY10
Model: Forester SG & SH
^ yeah, Greg. It's an unmistakable sound. By the time you hear it, the joint is rooted. Generally easiest to hear doing full lock circles at low speed in each direction.
Next check point is to examine all the boots for damage and/or grease leaks.
  #12
Unread 19th February 2016, 08:52 AM
corsa79's Avatar
corsa79 corsa79 is offline
Year: 2005
Model: Forester xt my06
Transmission: Manual
corsa79 is on a distinguished road
thanks gyes as I said have just replaced front drive shafts (CVs included ) got a new top hat replacing tomorrow.. Think its is it because sounds high in suspension. Sounds like its coming from glovebox in car. will keep you posted as might help someone else.
  #13
Unread 20th February 2016, 12:12 AM
corsa79's Avatar
Year: 2005
Well replaced noise is less but not gone. Glade I done it as there was a fair bit of play top strut mount and rubber had seen better days. Next I will try steering end and sway bar ends and rubbers
  #14
Unread 22nd February 2016, 09:15 PM
gregjet's Avatar
gregjet gregjet is offline
Year: 2014
Model: xv
Transmission: manual
gregjet is on a distinguished road
The xv has developed a ticking/squelching noise in the front left. Cannot isolate at all. No idew what it is but there straight or turning and disappears as you go faster. Wheel turning frequency. Took all the stones out of the tread . rolled it back and forward with the wheel in the air. Can't find it. Soon as I go slow back again.????????
  #15
Unread 22nd February 2016, 09:53 PM
Ratbag's Avatar
Year: MY06, MY10
Did you check the entire tyre width for nails?
Also check that you haven't got a small branch/wire/whatever touching the driveshaft etc anywhere?
These things can sometimes be damnably hard to find, and once found often as obvious as anything.
The theory of the essential perversity of everyday inanimate objects ...
  #16
Unread 23rd February 2016, 02:10 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Subversive...
  #17
Unread 24th February 2016, 11:32 PM
gregjet's Avatar
Year: 2014
Model: xv
Found mine. I had my new wheels epoxy coated and the back faces and the nut tapers had been painted. The paint had crumbled and loosened the wheels. Had to tighten them all again. All were loose especially the fronts.
Word of advice, If you get you wheels painted remove the paint from the nut tapers and the rear wheel mating face or make sure they don't get painted.
  #18
Unread 24th February 2016, 11:37 PM
Ratbag's Avatar
Year: MY06, MY10
Good to hear, Greg. Good advice too .
  #19
Unread 25th February 2016, 06:37 PM
havachat's Avatar
havachat havachat is offline
Year: 2002
Model: Forester SG
Loose wheel nuts are more common than you think.
  #20
Unread 2nd March 2016, 09:07 AM
corsa79's Avatar
Year: 2005
Well just a quick update replaced sway bar links little less noise pretty well narrowed it down to tie rod end. Replacing tomorrow will update then.
