  #1
Unread 16th February 2016, 11:33 PM
corsa79's Avatar
corsa79 corsa79 is offline
Year: 2005
Model: Forester xt my06
Transmission: Manual
corsa79 is on a distinguished road
Default Ticking noise
Hi how is everyone. I have a noise front left like a ticking sound. It only occurs when turning left off the power. I cant hear it when under power. I have checked wheel bearings and have no play at all. I have looked for play in suspension but haven't noticed any. Can anyone give me any idea where to look. Car is a 2006 xt forester also has new front drive shafts but was doing it before installing.
  #2
Unread 17th February 2016, 12:24 AM
Robbks's Avatar
Robbks Robbks is offline
Year: 2010
Model: Forester 2.0D Premium
Transmission: 6 MT
Robbks is on a distinguished road
you can't use the wobble test for a wheel bearing in an AWD.
the driveshaft going through the hub holds it tight.
  #3
Unread 17th February 2016, 01:49 AM
Liberty Valance's Avatar
Liberty Valance Liberty Valance is offline
Year: 2007
Model: 2 x XT Foresters
Transmission: Auto
Liberty Valance is on a distinguished road
Does the ticking frequency change with speed?
If you coast through a left hand corner in neutral gear does it sound the same?
MY06 XT Luxury Onroad
MY07 XT Luxury Offroad
  #4
Unread 17th February 2016, 01:58 AM
Ratbag's Avatar
Ratbag Ratbag is online now
Year: MY06, MY10
Model: Forester SG & SH
You can, Rob.
I've done it on a rear wheel bearing on a 199x OB/Liberty wagon.
  #5
Unread 17th February 2016, 06:31 AM
corsa79's Avatar
Year: 2005
Thanks everyone its weird it might be a bit quicker with speed but coasting with foot on clutch turning left it does it the worst or in gear coasting down hill slight left. its weird comes and goes a little. I also would of thought if it was a wheel bearing it would be all the timeturning eather way
  #6
Unread 17th February 2016, 07:13 AM
Ratbag's Avatar
Year: MY06, MY10
Gidday C79
In my friends' Subie with the dead rear wheel bearing (p/s rear), it would clunk when throwing into a series of sharpish r/h corners. No noise when going straight or on the same sort of l/h corners (going up Marble Hill road in the Adelaide Hills).
Vigorously rocking the car from side to side using the top of the rear p/s wheel showed both looseness and made the same kind of knocking noise (different from what I could hear inside the car, of course).
Informed our friends to have it replaced ASAP!
  #7
Unread 17th February 2016, 09:38 AM
corsa79's Avatar
Year: 2005
Thanks well I tried rocking side to side vigorously and no noise. So tried bouncing the front corner and got a clunk that isn't in any other corner. Sounds like it was coming from suspension. Has anyone ever had a top hat become buggerd.
  #8
Unread 17th February 2016, 04:40 PM
Yep! The bearings can fail.
  #9
Unread 17th February 2016, 06:50 PM
Robbks's Avatar
Year: 2010
Transmission: 6 MT
Had the top-hat centre nut come loose and rattle
otherwise look at LCA bushes, they always fail and Swaybar end-links
  #10
Unread 18th February 2016, 05:17 PM
gregjet's Avatar
gregjet gregjet is offline
Year: 2014
Model: xv
Transmission: manual
gregjet is on a distinguished road
Always though the diagnostic for sick CV joints was ticking when turning a corner.
