Go Back   OFFROADSUBARUS.COM > General Forums > New Member Introductions
  #21
Unread 23rd December 2017, 03:49 AM
1WD Foz 1WD Foz is offline
Year: 98
Transmission: Manual 5 speed
@Kevin Thanks for the body lift advice mate!
never looked into it tbh, will check it out
The SF came stock with 200mm of clearance which is ok but not great.
So far with the factory plastic sump guard I've only lightly tapped it once, but I've reversed away from tracks more times than i can count that i would try if i had a little more clearance and a proper sump guard which i intend to make myself (i hope).
I would like to think im extra safe while off-roading, choosing the best line on foot before attempting anything in the foz, so far I've been thru some stuff i probably shouldn't have but managed to find/make a chicken track around the bad stuff, then a couple of times i just parked and filled the bog hole with dead tree's, worked a treat
1WD
  #22
Unread 23rd December 2017, 04:21 AM
^ way to go
  #23
Unread 28th December 2017, 05:01 AM
temmah temmah is offline
Year: 2016
Transmission: CVT
temmah is on a distinguished road
Welcome 1WD Foz,
"I promise i will lift my Foz for me and my wife only" - Thats gold! I fully agree, well my wife needs a few days/weeks of convincing...
2016 Forester 2.5L CVT - SubaXtreme Bash Plate
  #24
Unread 29th December 2017, 01:04 AM
Year: 98
hahaha Thanks heaps temmah
Im glad your on my level
Im sure if i slapped the full cost of my suspension upgrade on the table i wouldn't have a great response either
best to do in small doses, which may be harder to pull off with a 2016 model mind you
but even more rewarding when you succeed
while purchasing new standard height shocks and springs all round i was very carefully educating my wife about the SUBIELIFTOZ lift kit and what it could do for > US <
its been a long process trust me but we're nearly there
i just need to make up my mind which kit to go with
1WD
